Question - offline Bug Toolkit in LMS 3.2
Dec 9th, 2009
Hi there,
actually we are using offline EoX-Reports with downloading EoX/PSIRT-File from CCO as our servers aren't connected to the internet.
Are there any possibilites for offlining the Bug Tookit too?
I know that it's not possible downloading bug-db from CCO as filesize would be enormous.
Do you know how communication between CW2000-Server and CCO is estabilshed (maybe for configuring FWs)?
Or are there any plans to provide a sort of export-and-check with CCO functionality?
Thanks for any feedback
Joe Clarke Thu, 12/10/2009 - 07:49
No, it is not possible to offline this report.  All communication between RME and happens using HTTP and HTTPS to  So, you would need to open TCP ports 80 and 443 to's IP.
There are currently no plans to offline the bug toolkit report.  In fact, we have had so many problems with this report, it is more reliable to use directly which is why there is now a link to the Bug Toolkit on the RME report page.
