Bandwidth Utilization
Dec 10th, 2009
I want to measure the bandwidth utilization per interface basis,what is the command appart from the " sh interface " is there any
other tool....gve me a simple method to find the link utilization.
Please guide me.
Ravi
Edison Ortiz Thu, 12/10/2009 - 11:24
You haven't mentioned what type of hardware you have.
If you have Cat 6500, there is netflow
If you have Cat 4500, there is an option to purchase a Netflow card and gather the same info.
If you have Cat 3xxx, then you need CiscoWorks or a 3rd party NMS agent to collect information via SNMP.
Edison
tprendergast Thu, 12/10/2009 - 11:31
In my opinion, the best tool for this is something like cacti. It uses rrdtool to graph snmp interface statistics that you poll each switch/device for. I use cacti for every network I work on.
Check it out at http://cacti.net/
I hope that helps, rate if it does.
