Connecting sfp and sfp+ interfaces
Dec 10th, 2009
Hi all. Here from Spain.
¿How can i connect a Cisco switch Nexus 5000 to a Cisco switch 3750-E at 10 Gpbs of bandwith via copper cables? 3750's switches have a TwinGig module (10Gpbs, SFP interface), and i think also have a X2-10GB-CX4 transceiver module (http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbe67.html); cisco Nexus 5000 has SFP+ interfaces. ¿Is it possible? ¿Can i connect sfp to sfp+ and achieve 10Gbps?
Or how can i connect a Qlogic CNA 8152 http://www.qlogic.com/Products/ConvergedNetworking/ConvergedNetworkAdapters/Pages/QLE8152.aspx), SFP+, to a switch with SFP ports (Cisco Catalyst 3560E-12D,  http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7078/product_data_sheet0900aecd805bac22.html).
l ask all these questions because i would like to install a 10G-switched network among a NetApp 3140 and two vmware-servers with qlogic CNAs. And also connect that 10G-switch with a 3750-E stack at 10Gps.
Ufff,
Thanks in advance.
Reza Sharifi Thu, 12/10/2009 - 07:49
Hello Ufff,
For 3750-E to connect using 10Gig, you will need the X2-10Gig transceiver module (it could be single mode or multimode). The fiber connecter type you need is SC.
On the Nexus, if you are using a 10Gig SFP, then you need to have an LC type fiber connector.
So, to connect the 3750-E to Nexus, you need  an SC to LC patch cord.
In addition,  on the 3750-E if you want to have 4 1Gig SFPs, instead of 2 X2 10Gig modules you can use TwinGig module to do that.
Reza
santjoanCisco Thu, 12/10/2009 - 09:51
Hello Reza.
Ufff was an expression. Here Franky.
Ok. My concept about TwinGig was wrong. Thanks for your answer.
So, Nexus 5000 <-> 3750 = fiber, not CX4 copper, ok?
Nexus 5000 is so expensive...
And, if i had to connect two 3750s via X2-10Gb? Fiber? CX4 copper? Suppose i don't want to stack them.
Now i think... is it possible to join two 3750s via 20Gb-bandwith-Etherchannel?
Reza Sharifi Thu, 12/10/2009 - 10:07
Hello Franky!!!!
hmm, what does Ufff mean anyway? (Thanks for clarefication)
Right, fiber if you want to use the 10Gig interfaces
If you want to connect 2 3750s using X2-10Gb, then you have to use fiber
All the copper ports on the 3750 are 10/100/1000 no 10Gig
stacking is a different story.  You use the connectors in the back of the switch with a stacking+ cable to stack them, so don't get theses 2 confused
Yes, you can etherchannel the 2 10Gig from each switch
Reza
santjoanCisco Thu, 12/10/2009 - 11:36
Ufff : The first one was a long paragraph in english... i was tired at the end.
And what about Cisco X2-10GB-CX4?, it's copper: (http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd801f92aa.html)
From http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbe67.html :
X2 for Catalyst 3750-E Series
X2-10GB-ER=
10GBASE-ER X2 Module
X2-10GB-LR=
10GBASE-LR X2 Module
X2-10GB-SR=
10GBASE-SR X2 Module
X2-10GB-CX4=
10GBASE-CX4 X2 Module
X2-10GB-LX4=
10GBASE-LX4 X2 Module
X2-10GB-LRM=
10GBASE-LRM X2 Module
Is it posible? Cheaper? Less perfomance?
