Problem with access sharing printers in vpn ipsec L2L
Dec 10th, 2009
Please I need Your help, in fact I have set up a vpn IPsec L2L between a router and an ASA5510 the tunnel is working very well, but I am not able to use a shared printer wchich is at the side of the ASA from the other side (router side). please tell me if I have to open any particular port on my ASA.
Thank you very much for your answer
Pravin Phadte Wed, 12/16/2009 - 23:41
Did you try to ping from you machine to the printer ?
If the ping did work. You can try to http or https to that ip and see if you are able to reach the printer ?
