FAX2MAIL solution with Cisco MGCP routers
Dec 10th, 2009
Can somebody advice me Cisco solution for FAX to Mail.
Also, It can be not Cisco solution
Thank you!
David Hailey Thu, 12/10/2009 - 16:40
I am assuming you want a Fax over IP solution that works with Cisco MGCP gateways but isn't the Cisco Fax Server which is an OEM of OpenText Right Fax.  Is that a correct rundown?
If so, check out XMediusFax.  Flexible installation options and definitely works with Cisco.  That would be my first choice.
