E1 link with NM-2CE1T1-PRI module
Dec 10th, 2009
Hi Guys,
             I'm not very familiar with this card, I have this problem , when i type sh ip int brief ;
rtr2#sh ip int brief
Interface                  IP-Address      OK?       Method   Status                Protocol
GigabitEthernet0/0         172.21.40.5     YES NVRAM  up                    up
GigabitEthernet0/1         172.21.40.5     YES NVRAM  standby mode    down
Serial1/0:0                10.20.197.1          YES manual    reset                 down
Serial1/1:0                unassigned      YES manual administratively down down
Serial2/0:0                unassigned      YES manual administratively down down
Serial2/1:0                unassigned      YES unset  reset                 down
Serial3/0:0                unassigned      YES unset  reset                 down
Serial3/1:0                unassigned      YES unset  reset                 down
Serial4/0                  unassigned      YES manual down                  down
Serial4/1                  unassigned      YES manual down                  down
Serial4/2                  unassigned      YES unset  administratively down down
Serial4/3                  unassigned      YES unset  administratively down down
NVI0                       unassigned      YES unset  up                    up
Multilink120               172.21.80.1     YES manual down                  down
may i know what does this reset mean instead of down status?
Thanks!
Armando Yesua G... Thu, 12/10/2009 - 09:24
  • Cisco Employee,
what model of router is this?
did you tried an OIR ?
I have seen this happening when OIR is not supported, so a reload of the box is needed.
or when having a faulty card.
please send more details of the issue, like show version, and steps applied to this card so far.
regards
Yesua.
obah Thu, 12/10/2009 - 10:52
Hi  Yesua,
                   The router is 3825 running ios ver Version 12.4(1c), config i believe is correct..
card type e1 1
card type e1 2
card type e1 3
controller E1 1/0
line-termination 75-ohm
channel-group 0 unframed
controller E1 1/1
controller E1 2/0
controller E1 2/1
controller E1 3/0
controller E1 3/1
interface Serial1/0:0
description E1 to Balun 28-A-1 (MCB)
bandwidth 2048
ip address 10.20.X.X 255.255.255.252
ip access-group 199 in
ip nat outside
no cdp enable
interface Serial1/1:0
no ip address
shutdown
interface Serial2/0:0
no ip address
shutdown
I not remove or insert the module..
The RA led is amber, could it be the remote side down?
paolo bevilacqua Thu, 12/10/2009 - 11:02
  • Hall of Fame,
    Founding Member
Take "show controllers E1".
Most likely, bad cable or circuit failure.
