Problem to run Cisco Supervisor Desktop
Answered Question
Dec 10th, 2009
Hi Guys,
My Customer have a IPCCX 5.0.2_SR02_Build045. I did download software CSD and installed in my machine, when, I try open or load the CSD it appear the message: "An error was received from the LDAP server. Please view the log file for more information".  I did the test out off network, in a machine stand alone. Any have Idea why is occuring this problem?
Wilson Santana
Correct Answer by Rajiv Lal about 7 years 4 weeks ago
Hi Wilson,
Run the postinstall.exe (c:/programfiles/cisco/desktop/bin/postinstall.exe) on the PC where you have installed the CSD and point it to correct UCCX ip Address and also seclect the correct NIC which appears at the last section of postinstall.exe.
Please rate this reply
Rajiv
Overall Rating: 5 (2 ratings)
Correct Answer
Rajiv Lal Tue, 12/22/2009 - 11:50
Hi Wilson,
Rajiv
Paul McGurn Mon, 04/07/2014 - 15:27
I had this error pop up for some CAD users after a CCX Engine restart in 8.5.1 SU4.  The fix in their case was changing their Team assignment in the Resource page, saving, then changing it back, and re-saving.  I'm guessing some kind of corruption happened during the engine restart or failover process in the HA cluster.
Jeremy Brown Wed, 09/24/2014 - 08:32
I tried this on a 9.0.2 UCCX and it worked great for me. The issue was following the user across various CAD PCs so it could not have been the instal as the other answer here.
