Top senders stats
Dec 10th, 2009
Hi there,
does somebody know how I can retrieve stats like top senders IP or top sender domain using XML stats page or something else?
I like to use some script which are running against tht M appliance.
mychrislo_ironport Thu, 12/10/2009 - 13:30
If you are looking at standard reporting (same ones in the GUI). I think you can set your M to email the pdf/csv to you.
If you want more automation. I believe AsyncOS 6.4/5 has a reporting api to retreive the csv.
https://supportportal.ironport.com/irppcnctr/srvcd?u=http://secure-suppo...
REPORTING API OVERVIEW
The Reporting API feature allows you to download the same data collected by the Email Security Monitor component of the IronPort Email Security appliance or Security Management appliance in a comma separated value (CSV) format. This format allows users to integrate the IronPort appliance's data gathering capabilities into other IT and business reporting systems.
DOWNLOADING REPORTING DATA
You can retrieve the data used to build the charts and graphs in the Email Security Monitor feature via HTTP. This is useful if you plan to perform further analysis on the data via other tools. The data is available in standard comma separated value (CSV) format. The easiest way
to get the HTTP query you will need is to configure one of the Email Security Monitor pages to display the type of data you want. You can then simply click the Export... link to initiate the download process.
Retrieving CSV Data via Automated Processes
I did not try. And i also did not know if it works for M. But I think it should.
