Modify Calling Name - TCL Script
Dec 10th, 2009
I have SIP connection on a 2800 gateway that also terminates two PRI's.  The PBX connected via the SIP trunk can only send a single Caller Name per line, ie for John Smith it sends out John Smith.  They would like to have the personal name sent internally but to the PSTN they would like "Company X" displayed.  A colleague forwarded me an old TCL script that can be used on a VoIP dial peer to overwrite the Caller Name which is exactly what I need, unfortunately it was written in 2003 and some of the commands that are used to implement this script no longer exist in IOS it seems (call application commands).
Does anyone have a newer version of this script or an alternative way to accomplish this?
Paolo Bevilacqua Thu, 12/10/2009 - 11:42
  • Hall of Fame,
    Founding Member
Currently, there are limited configuration facilities to handle names in IOS.
If you are interested  in acquiring a TCL/IVR script that does that, contact me at the address present in my profile.
jeroenhermans Tue, 01/26/2010 - 06:54
I'm trying to accomplish the same.
I have a 2811 running IOS 12.4.22T with CME 7.0.1. The IP address of this box is 192.168.130.2
I have uploaded the caller_name.tcl script to the flash of the router and added the command tftp-server flash:caller_name.tcl
I have created an application :
application
service caller tftp://192.168.130.2/caller_name.tcl
As the script documentation is saying, I have added a dial peer :
dial-peer voice 4000 pots
description Incoming PSTN Calls
service caller
incoming called-number 99999999..$
direct-inward-dial
Next to this, I have a database that has my names and numbers and a webpage that connects to this database.
if I run the webpage from the browser like this : http://IP_of_web_server/IPTelephony/index.php?ani=phone _number
then I get a name matching this phone number printed on the screen.
However, nothing different is being displayed on the screen of my ipphone when I dial from a CI that is registered in te DB. I just see the normal cli on the screen as before.
Any help in getting this to work is appreciated.
Jeroen
Paolo Bevilacqua Tue, 01/26/2010 - 15:24
  • Hall of Fame,
    Founding Member
Is this one of my script? You can contact me at the address present in my profile if interested in acquiring it and having it work 100%.
jeroenhermans Wed, 01/27/2010 - 02:55
Thanks for your reply. Not sure who wrote the script, I downloaded it from a different forum.
Anyway, in the mean time I got it to work perfectly. The issue was with my webpage, it was set to accept it via _GET and not _POST.
Do you know if it is also possible to push a picture of the caller to the phone?
Jeroen
Paolo Bevilacqua Thu, 01/28/2010 - 07:38
  • Hall of Fame,
    Founding Member
No, that would require additional programming in XML and I'm not even sure it would work.
Note, if the script is not the one I wrote, chances are that transfer calls is not possible.
lorife_82a Thu, 03/04/2010 - 07:40
Hi! please do you think you could send me the webpage you created? I got the same problem...
thank you for your help...
samhopealpha Tue, 09/04/2012 - 02:21
should I replaced the
to my own incoming pattern as follow?
incoming called-number 9...
Paolo Bevilacqua Tue, 09/04/2012 - 05:23
  • Hall of Fame,
    Founding Member
Please open new thread for new problems, detailing them in full.
Paolo Bevilacqua Tue, 09/04/2012 - 10:17
  • Hall of Fame,
    Founding Member
You can refer to the site mentioned in my profile for a fully working and supported solution.
samhopealpha Tue, 09/04/2012 - 22:01
I have visited your profile, but I can't find where is it, could you give me a direct link?
Thank you
Paolo Bevilacqua Tue, 09/04/2012 - 22:53
  • Hall of Fame,
    Founding Member
Just read my profile and it is at the very end. My email address is also there.
Related Content
