FXO in India
Dec 10th, 2009
There is a small office in india and they have one POTS line that we are trying to plug into a 2811 that has an fxo port. Supossedly the line works just fine if they hook up a Analog phone to it. However when they plug it into the router they can not make any calls. This is a H323 Gateway registered to a UCM version 6.1.  I am getting a Disconnect Cause =  47 on my debug. However if the line is not plugged into the router I get a Disconnect Code = 34 so I am assuming something is plugged in to my port. But I am not sure of why the calls are failing. Here is a debug for calling a local number.81 is the access code and it is matching this outgoing dial-peer
dial-peer voice 2 pots
destination-pattern 81T
direct-inward-dial
port 0/1/0
001088: Dec 10 14:36:32: //-1/80A57E502C00/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=4699
   ----- ccCallInfo IE subfields -----
   cisco-ani=4699
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8128578000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1
001089: Dec 10 14:36:32: //-1/80A57E502C00/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x45D7B368, Call Info(
   Calling Number=4699(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8128578000(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=118
001090: Dec 10 14:36:32: //-1/80A57E502C00/CCAPI/ccCheckClipClir:
   In: Calling Number=4699(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
001091: Dec 10 14:36:32: //-1/80A57E502C00/CCAPI/ccCheckClipClir:
   Out: Calling Number=4699(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
001092: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=4699(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8128578000(TON=Unknown, NPI=Unknown))
001093: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/cc_process_call_setup_ind:
   Event=0x4612AEB0
001094: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccCallSetContext:
   Context=0x44D5BEA8
001095: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 118 with tag 1 to app "_ManagedAppProcess_Default"
001096: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccCallProceeding:
001097: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=2, Params=0x44D5CB38, Progress Indication=NULL(0)
001098: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccCheckClipClir:
001099: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccCheckClipClir:
001100: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccCallSetupRequest:
   Destination Pattern=81T, Called Number=8128578000, Digit Strip=TRUE
001101: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=4699, Final Destination Flag=TRUE,
   Guid=80A57E50-C04D-11B2-2C00-7801C0A8634A, Outgoing Dial-peer=2
001102: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=4699
   cisco-ani=4699
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8128578000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
001103: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4618F430, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=4699(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8128578000(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
001104: Dec 10 14:36:32: //119/80A57E502C00/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
001105: Dec 10 14:36:32: //119/80A57E502C00/CCAPI/ccCallSetContext:
   Context=0x44D5CAE8
001106: Dec 10 14:36:32: //118/80A57E502C00/CCAPI/ccSaveDialpeerTag:
001107: Dec 10 14:36:32: htsp_timer_stop3 htsp_setup_req
001108: Dec 10 14:36:32: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
001109: Dec 10 14:36:32: [0/1/0] set signal state = 0xC timestamp = 0
001110: Dec 10 14:36:32: htsp_timer - 1300 msec
001111: Dec 10 14:36:32: //119/80A57E502C00/CCAPI/cc_api_call_proceeding:
   Interface=0x4618F430, Progress Indication=NULL(0)
001112: Dec 10 14:36:32: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
001113: Dec 10 14:36:32: htsp_timer_stop2
001114: Dec 10 14:36:32: htsp_timer - 1300 msec
001115: Dec 10 14:36:34: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
001116: Dec 10 14:36:35: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
001117: Dec 10 14:36:35: htsp_timer - 350 msec
001118: Dec 10 14:36:35: //119/80A57E502C00/CCAPI/cc_api_call_cut_progress:
   Interface=0x4618F430, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
001119: Dec 10 14:36:35: //119/80A57E502C00/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
001120: Dec 10 14:36:35: //118/80A57E502C00/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
001121: Dec 10 14:36:35: //118/80A57E502C00/CCAPI/ccCallCutProgress:
001122: Dec 10 14:36:35: //119/80A57E502C00/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
001123: Dec 10 14:36:35: //118/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46710F8C, callID1=0x76, callID2=0x77, tag=0x0)
001124: Dec 10 14:36:35: //118/80A57E502C00/CCAPI/ccConferenceCreate:
   Conference Id=0x46710F8C, Call Id1=118, Call Id2=119, Tag=0x0
001125: Dec 10 14:36:35: //118/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
001126: Dec 10 14:36:35: cc_api_get_xcode_stream : 4162
001127: Dec 10 14:36:35: //118/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x26, Source Interface=0x45D7B368, Source Call Id=118,
   Destination Call Id=119, Disposition=0x0, Tag=0x0
001128: Dec 10 14:36:35: htsp_call_bridged invoked
001129: Dec 10 14:36:35: //119/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x26, Source Interface=0x4618F430, Source Call Id=119,
   Destination Call Id=118, Disposition=0x0, Tag=0xFFFFFFFF
001130: Dec 10 14:36:35: //118/80A57E502C00/CCAPI/cc_generic_bridge_done:
001131: Dec 10 14:36:35: //118/80A57E502C00/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x26, Destination Call Id=119)
001132: Dec 10 14:36:35: //119/80A57E502C00/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x26, Destination Call Id=118)
001133: Dec 10 14:36:35: //119/80A57E502C00/CCAPI/cc_api_caps_ind:
   Destination Interface=0x45D7B368, Destination Call Id=118, Source Call Id=119,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
001134: Dec 10 14:36:35: //119/80A57E502C00/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
001135: Dec 10 14:36:35: //118/80A57E502C00/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x26, Call Id1=118, Call Id2=119
001136: Dec 10 14:36:36: htsp_process_event: [0/1/0, FXOLS_WAIT_CUT_THRU, E_HTSP_EVENT_TIMER]fxols_handle_cut_thru
001137: Dec 10 14:36:36: htsp_timer_stop
001138: Dec 10 14:36:36: //119/80A57E502C00/CCAPI/cc_api_call_connected:
   Interface=0x4618F430, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
001139: Dec 10 14:36:36: //119/80A57E502C00/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
001140: Dec 10 14:36:36: //118/80A57E502C00/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
001141: Dec 10 14:36:36: //119/80A57E502C00/CCAPI/cc_api_get_called_ccm_detected:
001142: Dec 10 14:36:36: //118/80A57E502C00/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
001143: Dec 10 14:36:36: //118/80A57E502C00/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=118
001144: Dec 10 14:36:36: //119/80A57E502C00/CCAPI/cc_api_get_called_ccm_detected:
001145: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x45D7B368, Call Id=118
001146: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
001147: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
001148: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/ccConferenceDestroy:
   Conference Id=0x26, Tag=0x0
001149: Dec 10 14:36:48: //118/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
001150: Dec 10 14:36:48: //119/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=118, Disposition=0x0, Tag=0x0
001151: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/cc_generic_bridge_done:
001152: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
001153: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
001154: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/cc_api_get_transfer_info:
001155: Dec 10 14:36:48: //119/80A57E502C00/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
001156: Dec 10 14:36:48: //119/80A57E502C00/CCAPI/ccCallDisconnect:
001157: Dec 10 14:36:48: //119/80A57E502C00/CCAPI/cc_api_get_transfer_info:
001158: Dec 10 14:36:48: htsp_timer_stop3
001159: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x45D7B368, Tag=0x0, Call Id=118,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
001160: Dec 10 14:36:48: //118/80A57E502C00/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
001161: Dec 10 14:36:48: htsp_process_event: [0/1/0, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
001162: Dec 10 14:36:48: htsp_timer_stop
001163: Dec 10 14:36:48: htsp_timer_stop2
001164: Dec 10 14:36:48: htsp_timer_stop3
001165: Dec 10 14:36:48: [0/1/0] set signal state = 0x4 timestamp = 0
001166: Dec 10 14:36:48: htsp_timer - 2000 msec
001167: Dec 10 14:36:48: //119/80A57E502C00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4618F430, Tag=0x0, Call Id=119,
001168: Dec 10 14:36:48: //119/80A57E502C00/CCAPI/cc_api_call_disconnect_done:
001169: Dec 10 14:36:48: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
001170: Dec 10 14:36:50: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
001171: Dec 10 14:36:50: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
Paolo Bevilacqua Thu, 12/10/2009 - 11:45
  • Hall of Fame,
    Founding Member
What happens if you call into the router ?
kgroves42 Thu, 12/10/2009 - 12:36
I get a ring then a disconnect tone.
Here is the debug voip ccapi inout and vpm signaling
001393: Dec 10 15:41:27: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
001394: Dec 10 15:41:27: htsp_timer - 125 msec
001395: Dec 10 15:41:27: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
001396: Dec 10 15:41:27: htsp_timer - 10000 msec
001397: Dec 10 15:41:28: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
001398: Dec 10 15:41:28: fxols_ringing_not
001399: Dec 10 15:41:28: htsp_timer_stop
001400: Dec 10 15:41:28: htsp_timer_stop3 htsp_setup_ind
001401: Dec 10 15:41:28: [0/1/0] get_local_station_id calling num= calling name= calling time=12/10 15:41  orig called=
001402: Dec 10 15:41:28: //-1/39BE02DF806B/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0
001403: Dec 10 15:41:28: //-1/39BE02DF806B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4618F430, Call Info(
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7000(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
001404: Dec 10 15:41:28: //-1/39BE02DF806B/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
001405: Dec 10 15:41:28: //-1/39BE02DF806B/CCAPI/ccCheckClipClir:
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
001406: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7000(TON=Unknown, NPI=Unknown))
001407: Dec 10 15:41:28: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
001408: Dec 10 15:41:28: fxols_wait_setup_ack:
001409: Dec 10 15:41:28: [0/1/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
001410: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/cc_process_call_setup_ind:
   Event=0x4612BE90
001411: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccCallSetContext:
   Context=0x44D51F68
001412: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 126 with tag 2 to app "_ManagedAppProcess_Default"
001413: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccCallProceeding:
001414: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=11, Params=0x44D53838, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
001415: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccCheckClipClir:
001416: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccCheckClipClir:
001417: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccCallSetupRequest:
   Destination Pattern=7000, Called Number=7000, Digit Strip=FALSE
001418: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccCallSetupRequest:
   Account Number=, Final Destination Flag=TRUE,
   Guid=39BE02DF-E503-11DE-806B-D85C2F21ECF4, Outgoing Dial-peer=11
001419: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
001420: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x45D7B368, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7000(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=11, Call Count On=FALSE,
001421: Dec 10 15:41:28: //127/39BE02DF806B/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
001422: Dec 10 15:41:28: //127/39BE02DF806B/CCAPI/ccCallSetContext:
   Context=0x44D537E8
001423: Dec 10 15:41:28: //126/39BE02DF806B/CCAPI/ccSaveDialpeerTag:
001424: Dec 10 15:41:28: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
001425: Dec 10 15:41:28: htsp_timer - 120000 msec
001426: Dec 10 15:41:28: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0110]fxols_rvs_battery
001427: Dec 10 15:41:28: htsp_timer_stop2
001428: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x45D7B368, Call Id=127
001429: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
001430: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/cc_api_get_transfer_info:
001431: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=127
001432: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
001433: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/ccCallDisconnect:
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
001434: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/cc_api_get_transfer_info:
001435: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x45D7B368, Tag=0x0, Call Id=127,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
001436: Dec 10 15:41:38: //127/39BE02DF806B/CCAPI/cc_api_call_disconnect_done:
001437: Dec 10 15:41:38: //126/39BE02DF806B/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
001438: Dec 10 15:41:38: //126/39BE02DF806B/CCAPI/ccCallDisconnect:
001439: Dec 10 15:41:38: //126/39BE02DF806B/CCAPI/cc_api_get_transfer_info:
001440: Dec 10 15:41:38: htsp_pre_connect_disconnect, cdb = 47065800 cause = 26
001441: Dec 10 15:41:38: htsp_process_event: [0/1/0, FXOLS_PROCEED_RVS_BT, E_HTSP_PRE_CONN_DISC]
001442: Dec 10 15:42:08: htsp_process_event: [0/1/0, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
001443: Dec 10 15:42:08: htsp_timer_stop
001444: Dec 10 15:42:08: htsp_timer_stop2
001445: Dec 10 15:42:08: htsp_timer_stop3
001446: Dec 10 15:42:08: [0/1/0] set signal state = 0x4 timestamp = 0
001447: Dec 10 15:42:08: htsp_timer - 2000 msec
001448: Dec 10 15:42:08: //126/39BE02DF806B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4618F430, Tag=0x0, Call Id=126,
001449: Dec 10 15:42:08: //126/39BE02DF806B/CCAPI/cc_api_call_disconnect_done:
001450: Dec 10 15:42:08: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
001451: Dec 10 15:42:10: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
001452: Dec 10 15:42:10: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
arifsultanal Sun, 02/07/2010 - 03:02
I am from Bangldesh. And I am facing the same. Just ringtone after that disconnect. Calls are not going to destination.
I am using SIP without Proxy..
Kindly let me how is your problem solved.
Best Regards
Sultan Al Arif
+8801610005883
