static NAT with route map to exclude VPN
Answered Question
Dec 10th, 2009
We are having problems accessing some static NATted IPs over a VPN.  After doing some research, we learned you need to exclude traffic destined for the VPN from the static NAT using a route-map. So we did this:
10.1.1.x is the VPN IP pool.
access-list 130 deny   ip
access-list 130 permit ip any
route-map nonat permit 10
match ip address 130
ip nat inside source static route-map nonat
The above worked to fix the VPN issue but the IP is no longer available publicly via  What seems to happen is that the static NAT is not really working and this IP is being NATted with the PAT IP.
Any ideas on how to get this to work?
Correct Answer by Laurent Aubert about 6 years 10 months ago
The following example details exactly your case:
Try replacing the subnet by the host address.
It should work
Overall Rating: 5 (1 ratings)
