Cisco works LMS 2.5
Dec 10th, 2009
Hi friends,
          I installed LMS2.5 and installation was success...firstly I added 2 devices by giving SNMP strings and there IP address manually and they ware successfully added....but when I started discover devices by auto discover from campus manager admin not a single device discovered except 2 which are already added......I tried all the ways like giving IP range, and SNMP strings etc but no use...pls help me out what might be the reason and how to solve this issue.I need ur assistance,valuable suggestion ........pls help me.....
Farrukh Haroon Tue, 12/15/2009 - 11:54
The device discovery for version 2.x does not work that great. The one in 3.x is much better.
You can try doing a debug for device discovery and look for any  hints.
Farrukh
mshamkumar Tue, 12/15/2009 - 16:26
thanks for ur reply...actually i tried seed and all devices discovered.......thanks again for ur reply....i will try what u said too.....thanks..
