ASA 5510 Bootup failure
choona_pk
I have an ASA 5510. Our office does not operate 24hrs, so we shutdown every device at the day end and turn them on the next morning.
The ASA was working fine till yesterday evening, but today when we powered it on, it does not bootup nor does it show anything on console when it is powered on.
The front panel LEDs are as follows:
Power -> Solid Green
Status -> Solid Amber
Active -> Solid Amber
VPN   -> Solid Green
Flash -> Off
Now, we have not configured the VPN but its light is on. I checked the ASA Quick start guide but there is no Amber Active LED.
Please help!
Kureli Sankar
http://www.cisco.com/en/US/docs/security/asa/asa82/getting_started/asa5500/quick/guide/install.html#wp1038172
Pls. refer this link:
Status: Amber
Solid
The power-up diagnostics have failed
With the power-up diag failing I don't think you will be able to console in either.
Seem like to you have request an RMA if this unit is still under contract.
-KS
I have the same problem, do you know what is the problem?
If the units don't boot and you don't have lights or console output, like kusankar said, this is probably hardware and might need an RMA.
I hope it helps.
PK
