Can Not Create T3 Multilink on 7613
Answered Question
Dec 10th, 2009
I currently have two T3 multilinked on 7206vxr and need to move this multilink over to a new chasis (Cisco 7613, IOS 12.2(33) SRC4).
When I try to create the multilink on the 7613 it does not work. I'ev created multilinks before and have never had any issues. Attached is the show tech. Does anyone know why it doesn't work? Any assistance would be greatly appreicated.
Correct Answer by Giuseppe Larosa about 7 years 2 months ago
Hello David,
>> just so that I understand you correctly. I will have to break the bundle and create seperate /30 connections for each WAN link?
yes this is your only option
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 12/11/2009 - 00:58
Hello David,
you have
5    0  2 port adapter Enhanced FlexWAN        WS-X6582-2PA
see restrictions for distributed multilink in flexwan configuration guide
Distributed MLPPP is supported only for member links configured at T1/E1 or subrate T1/E1 speeds. Channelized STM-1/T3/T1 interfaces also support dMLPPP at T1/E1 or subrate T1/E1 speeds. Distributed MLPPP is not supported for member links configured at clear-channel T3/E3 or higher interface speeds.
http://www.cisco.com/en/US/docs/routers/7600/install_config/flexwan_config/features.html#wp84027
you need to move to two or three parallel L3 links
Hope to help
Giuseppe
davidhuynh5 Fri, 12/11/2009 - 09:02
Hi giuslar,
thanks.
Correct Answer
Giuseppe Larosa Fri, 12/11/2009 - 09:29
Hello David,
Hope to help
Giuseppe
davidhuynh5 Fri, 12/11/2009 - 13:15
As usual Guislar, thanks for your help. Please change your handle to "CiscoGod":-)
