VRRP and MAC address issue
Dec 10th, 2009
We have 2 switches (Switch 1 & 2) on our end and another 2 switches (Switch 3 & 4) on another end.
Tried running VRRP on Switch 1 & 2, but there seemed to be some mac address issue when failing over (Suspect a spanning port blocking issue)
Is the attached setup valid ?
Is there a way to set up redundancy using the 2 MetroEthernet lines.
Ganesh Hariharan Fri, 12/11/2009 - 10:33
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
What is the error you have encountered in switch 1 and 2 and redundancy can be achived by top two switches itself.
Ganesh.H
ciscodotty Fri, 12/11/2009 - 18:59
I was told there isn't a problem on our end, but rather the problem happened over Sw 3 and 4 which is not managed by us. I suspect that the one of the ports was in blocking mode. Could I be right in my suspicion?
Bear in mind that the Vlan 123 are over MetroEthernet lines.
