Cannot add a device in Common Services..
Dec 10th, 2009
When I add a device in CS ( I went through the wizard by entering display name, IP address, snmp string etc.. andclick Finish. However it does not show in Device summary. Why?
Any ideas?
Joe Clarke Fri, 12/11/2009 - 13:22
First, make sure pop-up blockers are disabled (i.e. pop-ups are allowed from the LMS server).  If you don't see any error after enabling pop-ups, and this server is integrated with ACS, then check the Common Services > Device and Credentials > Reports > Devices not configured in ACS report to see if the device shows up there.  If so, you will need to add this device as a TACACS+ client of the ACS server to which LMS is integrated.
