Plain external bookmarks?
Answered Question
Dec 11th, 2009
Is there any way to add bookmarks as external links that are NOT smart tunnels and NOT rewriten urls when using the VPN Portal?
Correct Answer by Todd Pula about 7 years 7 months ago
This is covered briefly in the ASA Command Line Guide.  By default, all clientless traffic will be rewritten.  You can use the content rewriting feature to disable rewriting for certain resources.  I have included a link to the feature for your reference.  In ASDM 6.2, you can find this under Remote Access VPN->Clientless SSL VPNAccess->Advanced->Content Rewrite.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/webvpn.html#wp1046626
Overall Rating: 5 (1 ratings)
Correct Answer
Todd Pula Wed, 12/16/2009 - 14:25
  • Silver, 250 points or more
dbgreekas Wed, 12/16/2009 - 15:34
I found that on my own Monday, but thanks for the reply.
