Same error in two scripts
Dec 11th, 2009
I am using some holiday scripts found on as a template and i have altered them to use UK date formay i.e DD/MM/YYYY. In both the holiday and the holidayapp script im getting down to the XML file part and getting the attached message. Something is expecting the XML file to be located in the user docs under the EN_US folder. All of the documents are stored in the right locations in the EN_GB folder. the XMLDocumnet variable is also set to the XML in the EN_GB folder.
gbljoba Fri, 12/11/2009 - 02:53
Ive got it!
i needed to change the document variable to DOC[Holidays.xml] @ L[en_GB]
