Multiple default routes
Answered Question
Dec 11th, 2009
Is there a way to let a router choose one of multiple default routes depending of source ip address or source interface?
I have a C4015 with multiple vlans. There is a firewall connected to this switch. The C4015 has a static route (0.0.0.0/0) pointed to the interface of the firewall.
For testing purposes i have a second firewall interface (with an ip adress in a different subnet) connected to the switch.
Now i want traffic to 0.0.0.0/0 with a specific source address or a specific source vlan interface to be routed to the second (test) firewall interface.
thanks in advance
Correct Answer by Ganesh Hariharan about 7 years 7 months ago
Yes for your requirement go with PBR check out the below link hope this will help you
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
Ganesh.H
Correct Answer by Jon Marshall about 7 years 7 months ago
thanks in advance
Dennis
Yes, you can use PBR (Policy Based Routing) to do this which allows you to set the next-hop based on source IP address.
Just to clarify - what exactly is your switch - haven't heard of a C4015 ?
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Fri, 12/11/2009 - 07:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
thanks in advance
Dennis
Jon
DennisV99_2 Fri, 12/18/2009 - 03:49
Jon, Ganesh.H,
Thanks.
I think PBR does what i'm looking for.
Jon,
It's a 4010
