12-11-2009 02:52 PM - edited 03-04-2019 06:56 AM
Hey GuY,
I am setting up a new remote on 1700 router. I could not find the following command under the tunnel interface :ip nhrp cache non-authoritative.
I upgraded and downgraded the IOS six times already. Can someone point me in the right direction? What is the exact IOS for 1760 that support this feature? I am doing something wrong?
GrandVagabond
Solved! Go to Solution.
12-11-2009 03:09 PM
Hello Jean,
What version of IOS are you running?
Can you post sh ver?
Reza
12-11-2009 03:09 PM
Hello Jean,
Reza
12-11-2009 03:39 PM
I have tried 12.4(13b), 12.4.(17) c1700-advsecurityk9-mz.123-20a.bin,c1700-advsecurityk9-mz.124-12.bin.
trere is the config below:
version 12.4
no service pad
service password-encryption
hostname VPN-Carl
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa authorization network localgroups local
aaa session-id common
memory-size iomem 25
ip cef
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp pool Contractor
network x.x.x.0 255.255.255.0
dns-server x.x.x.x
default-router x.x.x.x
netbios-name-server x.x.x.x
ip dhcp pool DHCPPOOL-Voice
network y.y.y. 255.255.255.0
option 150 ip y.y.y.y
default-router y.y.y.y
dns-server y.y.y.y
no ip domain lookup
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key 543b33rg0gles!8199 address z.z.z.z no-xauth
crypto isakmp keepalive 20 3
crypto ipsec transform-set cvp esp-3des esp-md5-hmac
mode transport
crypto ipsec profile nocvpn
set transform-set vpn
interface Tunnel1
bandwidth 1000
ip address t.t.t.t 255.255.255.240
no ip redirects
ip mtu 1436
ip nhrp authentication nocvpn
ip nhrp map multicast t.t.t.t
ip nhrp map y.y.y.y z.z.z.z
ip nhrp network-id 8199
ip nhrp nhs y.y.y.y
delay 1000
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key 543403819
tunnel protection ipsec profile nocvpn
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 2
interface FastEthernet4
ip address dhcp
duplex auto
speed auto
ip http server
no ip http secure-server
access-list 20 permit 192.x.r.0 0.0.0.255
access-list 20 permit 10.x.0.0 0.0.255.255
access-list 20 deny any
control-plane
line con 0
exec-timeout 999 0
no modem enable
line aux 0
line vty 0 4
access-class 20 in
exec-timeout 5 0
login authentication local_authen
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 20000 1000
end
12-11-2009 03:53 PM
Here is command reference guide for 12.3
I don't see the command you posted here
http://www.cisco.com/en/US/docs/ios/12_3/ipaddr/command/reference/ip1_i2g.html
Reza
12-11-2009 03:54 PM
This iswhen I downgraded the unit to 12.3 . Cisco web site claims that the command : ip nhrp cache non-authoritative this command was introduced in 12.3(7T): https://www.cisco.com/en/US/docs/ios/security/command/reference/sec_i2.html .
IOS (tm) C1700 Software (C1700-ADVSECURITYK9-M), Version 12.3(13b), RELEASE SOFT
WARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 11-Aug-05 13:18 by alnguyen
Image text-base: 0x8000816C, data-base: 0x81009648
ROM: System Bootstrap, Version 12.2(4r)XL, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-ADVSECURITYK9-M), Version 12.3(13b), RELEASE SOFTWARE
(fc2)
GP-OFFICE uptime is 0 minutes
System restarted at 06:46:49 UTC Wed May 11 2005
System image file is "flash:c1700-advsecurityk9-mz.123-13b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. 1760 (MPC860P) processor (revision 0x200) with 49152K/16384K bytes of memo
ry.
Processor board ID FOC07100SML (2976509824), with hardware revision BB67
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
If
cisco
12-11-2009 04:06 PM
12-11-2009 04:10 PM
There is no 12.3(T) available on the cisco web site.
12-12-2009 12:13 PM
Now Router is running the follow inmage 12.4(4)T8, but still cannot find the command mentionned above under the tunnel interface. Is there a prerequisit command that I have to type first below this command appears under the tunnel interface??
Cisco IOS Software, C1700 Software (C1700-ADVSECURITYK9-M), Version 12.4(4)T8, R
ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 10-Aug-07 14:21 by khuie
GP-OFFICE uptime is 8 minutes
System returned to ROM by reload
System image file is "flash:c1700-advsecurityk9-mz.124-4.T8.bin"
