Cisco support for G722.2 wideband codec
paolo bevilacqua Sat, 12/12/2009 - 07:39
  • Hall of Fame,
    Founding Member
If it is not mentioned anywhere, is not supported.
David Hailey Sat, 12/12/2009 - 21:25
  • Purple, 4500 points or more
Only G722 is supported right now.  After attending a number of sessions regarding the upcoming 8.0 product line, I haven't heard any mention of further support for wideband variants.  G.722 and iLBC are being talked about more and more but there are still a number of considerations on whether to use them or not.  For example, G722 on IP to IP sounds great...but to PSTN may not be so hot.  Also, there are capacity limitations - major ones at that in some lines.  So, with Unity Connection there is support for these codecs but use of them reduces port capacity by 50%...so the defaults are still sticking to G711 in most cases.  Happy Holidays to you all.
