Video and Voice over BRI
Answered Question
Dec 12th, 2009
I'm looking to lab voice and video over a BRI connection.  At this point I've got a CallManager lab set up with a SIP endpoint(XLITE) registered to a "internal" CM7.1 publisher.  The "internal" CM and a 2821 is setup to do MGCP BRI backhauling of one of the VIC2-2BRI-NT-TE interfaces(0/0/0).  The 2821 has a BRI cross connect wire between interfaces 0/0/0 and 0/0/1.  The 2821 is also configured for H323 and has dial peers associated with BRI interface 0/0/1.  Another "pstn" CM7.1 publisher registers with the 2821 via H323.  XLITE is registered as a SIP client to the "pstn" CM.
The lab was originally setup for only voice, so the dial-peer has  "codec g711u" within it.  As well, the BRI interfaces are setup with "incoming voice".  Can voice and video be configured to go across the BRI interfaces?  Will MGCP allow setup the setup of a video call?  Does anyone have an example config?
Correct Answer by paolo bevilacqua about 7 years 5 months ago
"native" video over isdn is supported, but not with mgcp and not within any certification curricula.
So I think you can ignore it.
Of course you can do video over data, but the vic is a voice only card, not data.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sun, 12/13/2009 - 13:17
  • Hall of Fame,
    Founding Member
Related Content
