2960G Switch port issue
Dec 13th, 2009
Dear All,
In our network we are using  cisco switch model WS-C2960G-24TC-L. One of the port on switch is unable to  receive request.
Before X Server on this port was running  fine . We came to known when other port of X server went down and this port couldn't takeup the  connectivity .
When we connect other server to this port and want to ping default gateway. The port is not getting response from default gateway.
We tried the following troubleshooting steps:
  • We connect the laptop and tried to ping the default gateway but no response
  • Changed the vlan on port still their was noresponse
  • shutdown / no shutdown on port
  • checked the configurating /subnet  ,duplex , speed on port
  • paket capture on switch port (request is generated from the port to the default gateway but port is not receiveing any request from deatination other side)
  • Other ports on same switch are able to receive request from default gateway.
  • we chage the cable ,no access list etc in between to default gateway.
NOTE: On port we are able to get the server's MAC address , but on show interface output we see port is receiving  input packets but no   output  packets are displayed.
GigabitEthernet0/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is xxx.xxx.xxx (bia xxx.xxx.xxx) --- able to get mac of server
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:59:22, output hang never
  Last clearing of "show interface" counters 01:56:28
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
    535 packets input, 36292 bytes, 0 no buffer
     Received 535 broadcasts (0 multicast)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
Please can any one help us to solve this problem or this port is damaged .
Your help is highly appreciated.
regards,
M.K
vvasisth Sun, 12/13/2009 - 02:46
  • Silver, 250 points or more
it could be a possibility tha the port is damaged but the output attached in you questions says there is nothing connected on the port ?
GigabitEthernet0/2 is down, line protocol is down (notconnect) <------- is there something conencted to this port ?
mkareemashraf Sun, 12/13/2009 - 03:24
Dear Varun,
Laptop is connected on this port .
Here's the output
GigabitEthernet0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is xxx.1xx.xx (bia xx.xxc.xx2)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  Last input never, output 00:00:01, output hang never
  Last clearing of "show interface" counters 03:33:16
     552 packets input, 37380 bytes, 0 no buffer
     Received 552 broadcasts (0 multicast)
Thanks for ur quick response
vvasisth Sun, 12/13/2009 - 03:31
did you tried connecting this pc to a diff port ?
does that work ?
clear the logs and see if the input and output packets are incrementing
if not then its a faulty port
glen.grant Sun, 12/13/2009 - 03:40
  • Purple, 4500 points or more
  Also during a maintenance window or after everyone has gone for the day  power cycle the switch and see if it recovers .
Leo Laohoo Sun, 12/13/2009 - 03:55
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If you say that moving the connection to a different port works then I'm suspecting the ASIC that controls the first 4 ports has failed.  What is the result of the "sh post" command?
mkareemashraf Mon, 12/14/2009 - 00:46
Thanks for u r response.
I cannot restart the switch because it is in porduction environment.
Even the POST test  is successfull
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
All other ports are working , even i connect the server from port 2 to port 4 ,it is working fine.
vvasisth Mon, 12/14/2009 - 00:48
did you tried doing a shut /o shut on the interface ?
vvasisth Mon, 12/14/2009 - 02:16
replace the switch
regards,
varun
Lucien Avramov Mon, 12/14/2009 - 03:17
  • Red, 2250 points or more
Get a maintenance window and power cycle the switch.
Replacing the switch is premature at this point.
Megan Brandenburg Fri, 11/04/2011 - 15:21
We are experiencing the same issue as described at the top of this discussion.  Has a solution been discovered for this issue?
Thank you for your help!
Leo Laohoo Fri, 11/04/2011 - 16:38
  • Hall of Fame,
    2017 LAN, Wireless
Hi Megan,
Let's try running a TDR.  If your connection is on a Gig port then it's good because this will test all four pairs.  Here are the command:
1.  Command:  test cable tdr interface ;
2.  Wait for about 5 to 7 seconds; and
3.  Command: show  cable tdr interface
Please post the output.
This test will determine if you have a Layer 1 issue.
