Why would my VPN Client connection window not appear?
Dec 13th, 2009
I recently switched to Windows 7 (32bit) and was able to get the latest Cisco VPN Client "vpnclient-win-msi-5.0.06.0160-k9" working with no issues.  Iused it with several connections very successfully. Two days later, I can start the client but the connection window never appears on the desktop.  I can see it in my bottom tray, and the System tray, but when you right-click and select "VPN Client..." nothing happens.  I un-installed, rebooted, re-installed, and the same thing is occuring.  I removed all the entries in the profiles directory, same thing.
Does anybody have any ideas?  I can't see any obivous errors at all.
Thank you!
