Unexpected AAA Behavior in Lab Setup
Dec 13th, 2009
I have attatched the config for my lab router in its entirety.  The lab is air-gapped so I'm not scrubbing anything from its config.  I configured some example server groups, and the servers are dummy servers to force a failed connection so that my understanding of the processing of an aaa authentication list is validated.  My final login option is local, and I have a user with privilege level 15 specified.  However, when I configured the telnet lines to use my list configured as 'RADIUS', I got an error stating that the list didn't exist.  But when you look at the config, it is there on the vty lines.  Also, when I login via telnet, I am not in privileged mode and I have to enter it manually.  Below is the output on the router as I configured my aaa new-model:
3825_Lab(config)#aaa group server radius RADIUS_PRIMARY
3825_Lab(config-sg-radius)#server 192.168.200.2
3825_Lab(config-sg-radius)#exit
3825_Lab(config)#aaa group server radius RADIUS_BACKUP
3825_Lab(config-sg-radius)#server 192.168.200.3
3825_Lab(config)#aaa group server tacacs+ TACACS_PRIMARY
3825_Lab(config-sg-tacacs+)#server 192.168.200.4
3825_Lab(config-sg-tacacs+)#exit
3825_Lab(config)#aaa group server tacacs+ TACACS_BACKUP
3825_Lab(config-sg-tacacs+)#server 192.168.200.5
3825_Lab(config)#aaa authentication login RADIUS group RADIUS_PRIMARY group RADIUS_BACKUP local
3825_Lab(config)#aaa authentication login TACACS group TACACS_PRIMARY group TACACS_BACKUP local
3825_Lab(config)#lin vty 0 4
3825_Lab(config-line)#login authentication RADIUS
AAA: Warning authentication list "RADIUS" is not defined for LOGIN.  <-----------------  Huh?  Didn't I just create that list 4 lines previous?
From the 'show run' it is applied to the interface:
line vty 0 4
logging synchronous
Since my server groups are dummy groups, it should fail the radius lookup due to no server response and fall back to 'local' authentication.  So why when I telnet in do I get dropped into 'user exec' mode rather than 'privileged exec' mode?  My username statement is:
username admin privilege 15 password 0 admin
Any suggestions?
Scott
rtjensen4 Mon, 12/14/2009 - 08:40
  • Bronze, 100 points or more
You may need to adjust somthing with the authorization settings. aaa authorization exec RADIUS group RADIUS_PRIMARY group RADIUS_BACKUP local maybe?
