H.323 CUCM support
Dec 13th, 2009
I have a working call manager version 4.1 and i will upgrade soon to version 6.1, I just need to know if I have to upgrade cisco h.323 router gateways and VG200 which are contacted through H.323 only.
Overall Rating: 3.5 (2 ratings)
gogasca Sun, 12/13/2009 - 22:57
  • Green, 3000 points or more
should work, depending the IOS u have, I would use the cucm compatibility matrix to make sure ur using at least the version stated there.
Jaime Valencia Mon, 12/14/2009 - 07:28
  • Cisco Employee,
  • Hall of Fame,
    2011
You can take a look at this doc for versions tested with each version:
Cisco Unified Communications System Release Summary Matrix for IP Telephony for Enterprise and Midmarket
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#wp1016708
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
