SRST Voicemail
Dec 14th, 2009
When the router is in SRST mode, users need to access their voicemail personal greeting via the voicemail button on the phone, I have everything else working except this.
unity connection 7 voicemail pilot is 3330
In response to a general voicemail greeting , the user can press a *  after the genereal voicemail announcement to get a prompt  to enter their user pin to get to their personal voicemail box
The configs:
vm-integration
pattern direct * CDN   <--------------------------------------  Not working
pattern ext-to-ext no answer * FDN
pattern ext-to-ext busy * FDN
dial-peer voice 3330 pots
destination-pattern 3330
call-manager-fallback
voicemail 3330
I tried using the above dtmf pattern direct and according to cco it should work.
However, it keeps going to the general voice mail instead of a personal greeting.
I tried using all variations of dtmf pattern direct but it just goes to the general voice mail or does nothing.
Any help appreciated.
Thanks.
Paul
Adam Thompson Mon, 12/14/2009 - 07:26
Paul,
In the configuration you have outlined, you have pattern direct * CDN defined. When a user presses their messages button, the following will be dialed: 3330*3330. This is probably why they are hearing the opening greeting and not their personal mailbox.
What you want to configure is pattern direct * CGN. For example, if ext. 1002 presses their messages button, the system will dial 3330*1002. This should allow the user to get to their personal mailbox when pressing the messages button on their phone.
I am assuming you have seen this document, but I figured I would offer it anyways:
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srs_mail.html
Adam
Please rate if helpful
