CSD issues with 32-bit Vista
Dec 14th, 2009
We provide clientless SSL VPN access to a network by using CSD and a Citrix farm on the back end.  It works great with XP clients.  However, with 32-bit Vista, it is hit or miss.  Untrusted Vista machines, which are forced to fully load CSD, often report CSD already running, please disconnect/delete, but even when going through with the disconnect/delete, the user faces the same error upon next connection.  We've made sure they only have a single (new) version of Java greater than 1.6 update 13.  We've had the user clear the IE and/or Mozilla (if using Mozilla) cache, clear the java cache and reduces its size.  Disable their personnel firewall while attempting the connection and still we get this error.  I appreciate any constructive feedback.
