Limit max calls based on DNIS on the PRI line
Dec 14th, 2009
I have the PRI line which has few DDI numbers. Is there any way that i could restrict the max number of simultaneous calls to the called DDI number?
lets say if the ddi number is ****123654 limit it to 5 calls. so max 5 concurrent calls can be landed to this number and the sixth call fail.
username DDI_Number user_maxlinks (number of connections)
I have tried the above command but its not working.
Can you please help me out?
paolo bevilacqua Mon, 12/14/2009 - 07:07
  • Hall of Fame,
    Founding Member
What router is that and which IOS version ?
t4tauseef33 Mon, 12/14/2009 - 08:05
Sorry about missing this information
Its 5400XM dial rack with IOS version Version 12.4(25a),
t4tauseef33 Tue, 12/15/2009 - 02:26
HI,
I have the following config on 5400XM. Can you please tell me where and how can i implement the ' called-number 5557528 max-conn 3' command? I have few other Profiles on the 5400Xm same like below. modem-pool command is not available in AS5400Xm and AS5350Xm. Please help me out.
resource-pool group resource Profile-1
range port 1/0 1/59
resource-pool profile customer Profile-1
limit base-size 60
limit overflow-size 0
resource Profile-1 speech
dnis group DNIS-Profile-1
interface Group-Async0
ip unnumbered Loopback0
encapsulation ppp
async mode interactive
peer default ip address pool IPPOOL
ppp authentication chap pap callin
group-range 1/00 1/59
line 1/00 1/59
no motd-banner
no exec-banner
exec-timeout 0 0
no flush-at-activation
no vacant-message
modem InOut
modem autoconfigure type MODEMCAP
autocommand  telnet 192.168.168.2 /stream
no activation-character
transport input all
escape-character NONE
autoselect during-login
autoselect ppp
autohangup
paolo bevilacqua Tue, 12/15/2009 - 03:53
  • Hall of Fame,
    Founding Member
Search with the box above to see if the command has changed and how.
t4tauseef33 Tue, 12/15/2009 - 04:34
The command seems to be there but seems not acceptable when you have resource pools enabled. Is there any way i can accomplish this with the configuration i have provided above. It should be very simple but don't know how to do it.
