Media Termination Point and Transcoding - do I need to use one?
Dec 14th, 2009
Hello All,
            I'am setting up a CUCM 7.0 deployment using CUBE.  I'am doing a sip trunk to the CUBE.  The CUBE to every destination region is G.729 and all internal calls are g.711.  My question is the need for a media termination point.  I guess I just need the media termination point demistified,  I know it can also function as a transcoder.  The SIP trunk is going to be transcoded to g.729 at CUCM so that means I would need to have the box , media termination point required, checked?  I'am doing H323 internally to all other gateways. Thanks
Jason
Volodymyr Morskyy Mon, 12/14/2009 - 08:08
  • Bronze, 100 points or more
AFAIK if your endpoints(phones) are supporting G729, there is no need in transcoding(in your case no transcoding is needed over the trunk).
If you are making an Ad-Hoc conference in HQ based on software conference bridge of your CUCM (G711 only) then you'll need to have a transcoder in HQ.
Seems like I answered just a part of your question)
Jaime Valencia Mon, 12/14/2009 - 08:21
  • Cisco Employee,
  • Hall of Fame,
    2011
" I guess I just need the media termination point demistified,  I know it can also function as a transcoder. " NO
An XCODER can work as an MTP, but an MTP CANNOT work as an XCODER.
This link discusses the MTP funtion and SIP trunk + MTP requirements:
Media Termination Point (MTP)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1046314
Read the section:
SIP Trunk MTP Requirements
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
