Router compatibility with Access Points
Dec 14th, 2009
I work in IT but am a novice to wireless.
I would like to find out if my Wireless Router is compatible with my Access Points if WAP security is turned on.
My current configuration is a Linksys Wrt54g ver 2.04.4 and 2 Cisco Air-Ap1231G-A-K9 system software version12.3(7)JA2
Right now it is working with the Linksys router serving out DHCP without security. My predecessor did not turn on security.
I did turn on WAP security on Router and the AP's but could not get connected. With 2 laptops I could see the AP's but could not connect to them with the passphrase. On the AP's I used the Express security menu.
My question is, should I upgrade the router? If yes, What would be the best fit to work with the AP1231g's?
