Did anyone tell me .. how to place a test call from E1 CAS controller on Cisco 3845 Router
nageswara.s
Hi All,
     Did anyone tell me .. how to place a test call from E1 CAS controller on Cisco 3845 Router and debug commands to capture the same.
Nagesh,
paolo bevilacqua
csim start
"debug vpm signal" and "term mon".
    Thanks for your help, I have place the test call and I am getting some error i am unable to call the outside number through PSTN. Below i am pasting the error log can you please check and help me on solving this issue. Required your fast responce since its some what urgent. Thanks for understanding.
config t       sim start 918752740255
csim: called number = 918752740255, loop count = 1 ping count = 0
*Dec 15 05:21:34.175:  (1) vnm_dsprm_hunt_channel htsp=0x66E1E1B0 next_free=0x66E1E778 LS=0
*Dec 15 05:21:34.175:  (2) vnm_dsprm_hunt_channel htsp=0x66E1E1B0 next_free=0x66E1E778
*Dec 15 05:21:34.175: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 3, 6, TGRM_CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
*Dec 15 05:21:34.175: //-1/xxxxxxxxxxxx/VTSP:(0/0/0:3):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x685096B8
*Dec 15 05:21:34.175: //-1/xxxxxxxxxxxx/VTSP:(0/0/0:3):-1:-1:-1/vtsp_insert_cdb:
*Dec 15 05:21:34.175: //-1/xxxxxxxxxxxx/VTSP:(0/0/0:3):-1:-1:-1/vtsp_process_event:
   [state:INVALID STATE MACHINE, event:E_CC_SETUP_REQ]
*Dec 15 05:21:34.175: htsp_timer_stop3
*Dec 15 05:21:34.175: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:-1:-1/vtsp_og_call_req:
   Echo Cancel=TRUE, Gain Control=0
   Auto Gain Control=FALSE, Dual Tone Detect Mask=0x0, Seq Tone Detect=FALSE
*Dec 15 05:21:34.175: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:-1:-1/vtsp_do_call_setup_req:
*Dec 15 05:21:34.175: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_dsm_opened_cb:
*Dec 15 05:21:34.175: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQ_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
*Dec 15 05:21:34.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/act_setup_req_pend_succ:
*Dec 15 05:21:34.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_request_call:
   Mode=0, Peer=10
*Dec 15 05:21:34.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_create_call_active_on_setup_req:
   Target Carrier ID=
   Source Carrier ID=htsp_setup_req
   Progress Indication=0, Info Trans Capability=0
   Calling Number=, TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed
   Called Number=918752740255, TON=Unknown, NPI=Unknown
*Dec 15 05:21:34.179: htsp_process_event: [0/0/0:3(6), R2_Q421_IDLE, E_HTSP_SETUP_REQ]
*Dec 15 05:21:34.179: r2_q421_seize(0/0/0:3(6)) E_HTSP_SETUP_REQ DNIS= ANI=
*Dec 15 05:21:34.179: r2_q421_seize(0/0/0:3(6)) Tx SEIZUREvnm_dsp_set_sig_state:[R2 Q.421 0/0/0:3(6)] set signal state = 0x0
*Dec 15 05:21:34.179: htsp_timer - 5000 msec
*Dec 15 05:21:39.179: htsp_process_event: [0/0/0:3(6), R2_Q421_OG_SEIZE, E_HTSP_EVENT_TIMER]
*Dec 15 05:21:39.179: r2_q421_seize_to(0/0/0:3(6)) Tx CLEAR FWDvnm_dsp_set_sig_state:[R2 Q.421 0/0/0:3(6)] set signal state = 0x8
*Dec 15 05:21:39.179: htsp_timer - 1000 msec
*Dec 15 05:21:39.179: r2_reg_channel_disconnected(0/0/0:3(6))
*Dec 15 05:21:39.179: r2_reg_process_event: [0/0/0:3(6), R2_REG_IDLE, E_R2_REG_DISCONNECT(89)]
*Dec 15 05:21:39.179: r2_reg_disconnect_idle(0/0/0:3(6))
*Dec 15 05:21:39.179: r2_reg_timer_stop(0/0/0:3(6))
*Dec 15 05:21:40.179: htsp_process_event: [0/0/0:3(6), R2_Q421_OG_CLR_FWD, E_HTSP_EVENT_TIMER]
*Dec 15 05:21:40.179: r2_q421_clr_fwd_to(0/0/0:3(6))
*Dec 15 05:21:40.179: htsp_timer - 2000 msec
csim err csimDisconnected recvd DISC cid(180)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
VCHYZVG01#
*Dec 15 05:21:42.179: htsp_process_event: [0/0/0:3(6), R2_Q421_WAIT_IDLE, E_HTSP_EVENT_TIMER]
*Dec 15 05:21:42.179: r2_q421_wait_idle_to(0/0/0:3(6)) Tx IDLEvnm_dsp_set_sig_state:[R2 Q.421 0/0/0:3(6)] set signal state = 0x8
*Dec 15 05:21:42.179: htsp_timer - 2000 msec
*Dec 15 05:21:42.179: htsp_process_event: [0/0/0:3(6), R2_Q421_WAIT_IDLE, E_DSP_SIG_1000]
*Dec 15 05:21:42.179: r2_q421_wait_idle(0/0/0:3(6)) Rx IDLE
*Dec 15 05:21:42.179: r2_reg_channel_disconnected(0/0/0:3(6))
*Dec 15 05:21:42.179: htsp_timer_stop
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQUEST, event:E_TSP_DISCONNECT_IND]
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/act_setup_pend_release_ind:
   Cause Value=41
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_ring_noan_timer_stop:
   Timer Stop Time=40969560
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_cc_call_disconnected:
   Cause Value=41
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_set_release_source:
   Release Direction=PSTN, Release Source=Called Party-PSTN
   Peer=10
*Dec 15 05:21:42.179: r2_reg_process_event: [0/0/0:3(6), R2_REG_IDLE, E_R2_REG_DISCONNECT(89)]
*Dec 15 05:21:42.179: r2_reg_disconnect_idle(0/0/0:3(6))
*Dec 15 05:21:42.179: r2_reg_timer_stop(0/0/0:3(6))
   [state:S_SETUP_REQUEST, event:E_CC_DISCONNECT]
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/act_disconnect_no_dsp_chan:
   Hairpin=FALSE, Cause Value=41, Previous Cause Value=41htsp_release_req: cause 41, no_onhook 0
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/vtsp_do_call_history:
   Coder Rate=-1
   Peer=10
*Dec 15 05:21:42.179: htsp_process_event: [0/0/0:3(6), R2_Q421_IDLE, E_HTSP_RELEASE_REQ]
*Dec 15 05:21:42.179: r2_q421_idle_release(0/0/0:3(6)) E_HTSP_RELEASE_REQ
*Dec 15 05:21:42.179: r2_q421_idle_release(0/0/0:3(6)) Tx IDLEvnm_dsp_set_sig_state:[R2 Q.421 0/0/0:3(6)] set signal state = 0x8
*Dec 15 05:21:42.179: TGRM: reg_invoke_tgrm_call_update(0, 0, 0, 3, 6, TGRM_CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_OUT)
   [state:S_SETUP_FAIL, event:E_TSP_DISCONNECT_CONF]
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:1:1/act_setup_fail:
*Dec 15 05:21:42.179: flex_dsprm_close_cleanup
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:-1:-1/vtsp_dsm_closed_cb:
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:-1:-1/vtsp_process_event:
   [state:S_CLOSE_DSPRM, event:E_VTSP_DSM_CLOSE_COMPLETE]
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:-1:-1/act_terminate:
*Dec 15 05:21:42.179: //180/8B7AD3E88135/VTSP:(0/0/0:3):-1:-1:-1/vtsp_timer_stop:
*Dec 15 05:21:42.179: //-1/8B7AD3E88135/VTSP:(0/0/0:3):-1:-1:-1/vtsp_free_cdb:
   CDB=0x685096B8
