Translation Patter for the last 2 digit
Dec 14th, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Can we do the translation patter for the last 2 digit?
For example, we can do this?
Translation Pattern: 222-333-XXXX (covert 10 digit Incoming DID to 4 digit)
Called Party Transform Mask: XXXX
So 222-333-1234 will ring to extension 1234
My questions:
Can we do this or how can we do this?
Translation Pattern: 222-333-55XX
To ring to phones with extension: 55XX
i just want to transform the last 2 digit of the phone number
Thank you
asandborgh Mon, 12/14/2009 - 10:04
Hi Sienz,
Maybe I'm missing something here but you should be able to do it exacly like your first example except your transform mask would be 55XX.  You alos should be able to set the siginificant digits setting on your gateway to 4, which should accomplish the same thing.
