NAC SNMP MAC notification traps not being sent
I have the switch set up for mac notification, and the switch has the below config. But no mac notification traps get sent to the CAM.
interface GigabitEthernet1/0/24
switchport access vlan 800
switchport mode access
snmp trap mac-notification added
spanning-tree portfast
snmp-server community **** RO
snmp-server community **** RW
snmp-server enable traps snmp linkdown linkup
snmp-server enable traps MAC-Notification
snmp-server enable traps stpx root-inconsistency loop-inconsistency
snmp-server host 10.101.90.20 version 2c ****
snmp-server host 10.101.90.20 **** MAC-Notification snmp
Below is a debug of snmp packets when a host it connected to the switch on port 1/0/24
1y29w: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24, changed state to up
1y29w: SNMP: Queuing packet to 10.101.90.20
1y29w: SNMP: V2 Trap, reqid 62, errstat 0, erridx 0
           sysUpTime.0 = 648642685
           snmpTrapOID.0 = snmpTraps.4
           ifIndex.10124 = 10124
           ifDescr.10124 = GigabitEthernet1/0/24
           ifType.10124 = 6
           lifEntry.20.10124 = up
1y29w: SNMP: V1 Trap, ent products.516, addr 10.202.1.2, gentrap 3, spectrap 0
           ifType.10124 = 6
1y29w: SNMP: Packet sent via UDP to 10.101.90.20
1y29w: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24, changed state to up
Am I missing something in the config or something?
Overall Rating: 4 (1 ratings)
Faisal Sehbai Mon, 12/14/2009 - 14:20
  • Gold, 750 points or more
Please post your SNMP receiver config on the CAM. Also, can you do a capture on the CAM to see if you're seeing the packets getting there?
To do the capture, in a SSH session, use this command: tcpdump -ieth0 'host ' -s0 -wcapture.pcap
Once you've captured the success/failure, hit Ctrl-C to kill the capture. You can then use WINSCP or any other SCP program to get that file off of the CAM for further analysis.
HTH,
Faisal
Related Content
