2900 CANNOT PING ITS GATEWAY
Dec 14th, 2009
HI all,
         I have a 2900 switch connected to 1700 series router. The router is configured as router on a stick with multiple DHCP pools, so the port connected to the switch is a trunk port at both end.
Hosts connected to the switch are able to grab dhcp address on their respestives vlan. Howver, from the switch ip I cannot ping the router and from the router I cannot ping the switch. For this example, let say that the IP is 10.0.0.0/24, 10.0.0.1 is the router IP address and 10.0.0.2 is the switch. I did add ip default-gateway 10.0.0.1 on the switch. But it still cannot ping 10.0.0.1.
Any ideas is more than welcome.
Jean Paul Enerst Mon, 12/14/2009 - 15:34
There is the config for the switch
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa authorization network localgroups local
enable secret 5 $1$O2H2$rTjfYZ8Ay73qs8qrpWF290
interface FastEthernet0/1
description TRUNK TO CONNECT TO 1760 F0/0
switchport mode trunk
interface FastEthernet0/2
shutdown
interface FastEthernet0/3
shutdown
interface FastEthernet0/4
description VOICE_VLAN
switchport access vlan 10
spanning-tree portfast
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
description VOICE-VLAN
interface FastEthernet0/8
interface FastEthernet0/9
description DATA_VLAN
switchport access vlan 20
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
shutdown
interface FastEthernet0/21
shutdown
interface FastEthernet0/22
shutdown
interface FastEthernet0/23
shutdown
interface FastEthernet0/24
shutdown
interface VLAN1
ip address 192.168.x.2 255.255.255.0
no ip directed-broadcast
no ip route-cache
ip default-gateway 192.168.x.1
access-list 10 permit 192.168.x.0 0.0.0.255
access-list 10 permit 10.x.x.0 0.0.255.255
access-list 10 deny   any
end
there is the router
version 12.4
hostname
boot-start-marker
boot-end-marker
enable secret 5 $1$3WaI$ca2G.pqG7xjTExp8IFXvN.
aaa new-model
aaa authorization exec local_authen local
aaa session-id common
memory-size iomem 25
clock timezone MDT -7
clock summer-time MDT recurring
ip cef
ip dhcp pool GP-VOICE-POOL
   network 10.x.x.0 255.255.255.0
   default-router 10.169.4.1
   option 150 ip 10.x.x.254
   dns-server 10.x.x.254
ip dhcp pool GP-DATA-POOL
   network 192.x.x.0 255.255.255.0
   default-router 192.x.x.1
archive
log config
  hidekeys
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key abcbbc address 209.x.x.x no-xauth
crypto isakmp keepalive 20 3
crypto ipsec transform-set adios esp-3des esp-md5-hmac
mode transport
crypto ipsec profile nopim
set transform-set adios
interface Tunnel1
bandwidth 1000
ip address 10.x.x.x 255.255.255.240
no ip redirects
ip mtu 1436
ip nhrp authentication nocvpn
ip nhrp map multicast 209.x.x.x
ip nhrp map 10.x.x.1 209.x.x.x
ip nhrp network-id 8199
ip nhrp nhs 10.x.x.1
delay 1000
tunnel source Ethernet1/0
tunnel mode gre multipoint
tunnel key cvvvv
tunnel protection ipsec profile adios
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.x.x.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 10.x.x.1 255.255.255.0
interface Ethernet1/0
ip address dhcp
full-duplex
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 10 permit 192.x.x.0 0.0.0.255
control-plane
line con 0
exec-timeout 999 0
password 7 10673A542B1206260D0A
logging synchronous
line aux 0
line vty 0 4
access-class 20 in
exec-timeout 5 0
login authentication local_authen
transport input telnet ssh
Jerry Ye Mon, 12/14/2009 - 15:39
In your switch, do the following and test
int vlan 1
no ip address
shut
int vlan 10
no ip route-cache
no shutdown
You didn't assign any IP address for VLAN 1 on the router's trunk interface.
jerry
glen.grant Mon, 12/14/2009 - 16:26
JEYE is correct you have your switch ip in vlan 1 and on the router you have the address space on the router in vlan 10  so there is no way it can reach the router because the switch is not tagging the traffic as vlan 10 traffic  , you have it one .  Either change the switch to 10 or change the router so its in vlan 1 instead of 10 .
