FXS Port 0 has no dial tone FXS Port 1 has dial
fruition3000
     For some reason port 0 on my FXS card does not provide dialtone.  The settings on port 0 and port 1 are identical and I have swapped out analog phones
Symtoms
I can call the phone attached to port 0 from port 1 on the same card.
The LED associated with port 0 comes on when the phone goes off the hook.
On port 0 the phone goes off hook, on hook, then off everytime I pick up the phone.
Any Ideas
mightyking
Level 6
Level 6
If you have "direct-inward-dial" configured under the FXO/FXS dial peers, remove them and try again.
MK
6 Replies 6
mightyking
Level 6
Level 6
MK
Your solution worked, thank you.  Any ideas on how to get call through to the FXS ports directly using DID numbers? When I remove the DID command from the dial-peer and try to dial in I get a second dialtone.
Do you have connection plar configured under the voice port?
voice-port 0/1/0
connection plar 1234 (extension where the call will be terminated)
MK
I am running CME on both routers and I am trying to place a call from WYRT1 to AZRT1 through the national or international pots dial-peer to a FXS port on AZRT1 with multiple numbers
No commands have been entered under the FXS Port.  I wanted to point multiple numbers to this FXS port and I wasn't sure if PLAR would be able to do this
hostname WYRT1
...Limited output.....
dial-peer voice 8 pots
description NATIONAL CALLING
preference 1
destination-pattern 91..........
direct-inward-dial
port 3/0:23
forward-digits 10
dial-peer voice 9 pots
corlist outgoing INT
description INTERNATIONAL CALLING
preference 1
destination-pattern 9011T
direct-inward-dial
port 3/0:23
prefix 011
hostname AZRT1
preference 1
destination-pattern 91[29]..[29]......
direct-inward-dial
port 1/0:23
forward-digits 10
preference 1
direct-inward-dial
port 1/0:23
prefix 011
dial-peer voice 1 pots
preference 1
destination-pattern 7573683333
direct-inward-dial
port 2/0
forward-digits all
dial-peer voice 2 pots
preference 1
destination-pattern 0112223334444555
direct-inward-dial
port 2/0
forward-digits all
dial-peer voice 3 pots
preference 1
destination-pattern 7184415453
direct-inward-dial
port 2/0
forward-digits all
Replace the extension with "X".  If your extensions are 4 digits then use "Connection plar XXXX" under voice port. This will mach any 4 digits number.
voice-port x/y/z
connection plar XXXX opx
MK
Sorry for the delay in communication.
Thank you for the suggestion but I was trying to setup this port to have multiple different numbers which do not fall into any specific range.
Example  800-555-1212, 214-728-2839, 0112833782901 all point to fxs port 0/1.  I would like to have call routed through the PRI and the have the phone ring directly.
