DAP rule for ezvpn remote
Dec 14th, 2009
I am currently using ezvpn for branch office and remote access and I have a plan to deploy SSL vpn.
The device i use is ASA5510.
At the same time i deploy SSL vpn, I will start using DAP.
My question is what kind of DAP rule i should create for ezvpn remote.
I fould out the way for ezvpn client in the thread below.
(select "application" endpoint attribute type and set the "client type" to "IPsec".)
https://supportforums.cisco.com/thread/255314;jsessionid=9D14A1315618488A914DE8DB621470A3.node0?tstart=-1
Does this work with ezvpn remote as well?
Thanks in advance.
taroyamada9999 Thu, 12/17/2009 - 18:41
I think I need to give some additiona information.
Since I currently do not use DAP, ezvpn remote and client is allowed to communicate by default DAP record which is DfltAccessPolicy.
After depolying SSL VPN, I would like to use DfltAccessPolicy to block the session. (like an "implicit deny all" in ACL)
I belive usually DfltAccessPolicy is used in this way..
That means I need to create another DAP rule for ezvpn remote and client to prevent being blocked.
My question is what kind of attribute I need to look at to allow ezvpn remote.
Thanks in advance.
