Router enters into Rommon frequently
Dec 14th, 2009
Hi Expert,
I dont know wether its right place to post this Issue,
My problem is router enter into Rommon mode for every 2-3 minutes after its gets hard reboot ( Turning ON & Off ),
Please find attached Doc of Router before entering into Rommon mode
Thanking You,
Leo Laohoo Tue, 12/15/2009 - 01:48
Your c1841 router is running 12.3(14)T3 IOS is this correct?
You have numerous crashinfo file that's it's filling up the compact flash memory card.  Can you post the latest one?
I'd recommend you try to upgrade the IOS to the 12.4 version before trying it out.  I'm suspecting that you have a hardware/NM/WIC-1BS/T that didn't like the IOS.
