CUEAC-Unable to hear the continuous ring, it just rings once and stops.
giftonabel
I have configured the CUEAC server and below are the details of it:
CUEAC Administration Version: 3.1.1.133
CUEAC Console Version: 3.1.1.511
When we get a call on the console, it rings only once instead of continuously ringing, even if the call is on the queue and not answered.(The problem is Intermmitent, sometimes if we close and login again it rings continuously for the first time, then again the same problem continues)
Tried checking with other systems also, the problem remains the same.
I tried doing the Ring settings on the Console ->Preferences, but still no progress.
Pls. suggest if anything more needs to be done.
rgds,
Gifton
Hi Marcus,
It sounds like this bug
CSCtc84599 Bug Details Bug #1 of 2 | < Previous            | Next >
Operator console rings only once for incoming calls
Symptom:
Conditions:
After upgrading to CUBAC 3.1.1.5, only the first call to the operator console will ring through the speakers until the operator picks up. All subsequent calls will ring through the speakers only once although the call still shows as being in queue.
Call handling is still working, but when you have more agents the other agents may not realize that there is calls waiting in queue.
Restarting the client console will allow the first call to work as above, but all subsequent calls will fail, so not really feasable as a workaround.
Workaround:
None
Further Information
The above issue is also seen in CUEAC 3.1.1.5.
Status
Fixed
Severity
1 - catastrophic
Last Modified
In Last 3 Days
Product
Cisco Unified Attendant Consoles
Technology
1st Found-In
3.1(1.5)
Fixed-In
Release-Pending
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
marcusdewaal
I have the same issue, did you find a solution?
Marcus
Hi Marcus,
Symptom:
Conditions:
Workaround:
None
Further Information
Status
Fixed
Severity
1 - catastrophic
Last Modified
In Last 3 Days
Product
Technology
1st Found-In
3.1(1.5)
Fixed-In
Release-Pending
Hope this helps!
Rob
This was indeed a bug, it has now been fixed.
