Explanation for the Softkeys on the SPA IP Phones?
Answered Question
Dec 15th, 2009
Is there any document that explains the Softkeys in more detail?
Beside the abbreviations it is sometimes not clear which function which softkey offers.
Daniel
Correct Answer by klogata about 7 years 6 months ago
In addition to the Quick Start Guides, the SPA 5XX User Guides have explanations of the softkeys:
http://www.cisco.com/en/US/products/ps10499/products_user_guide_list.html
For SPA 5XX: Keep in mind that with software release 7.3.7 (SIP) and 7.4.2 (SPCP), administrators can create their own softkeys and labels, so depending on the customization of the system, some softkeys may not be described in the general documentation.
If you are looking for the SPA9XX phones, the documentation is here:
http://www.cisco.com/en/US/partner/products/ps10033/tsd_products_support_series_home.html
Hope this helps.
Correct Answer by Alberto Montilla about 7 years 6 months ago
Dear Sir;
I suggest you check the Quick Setup/Reference Guides, in the documentation section. It provides an explanation for the soft-keys.
https://www.myciscocommunity.com/docs/DOC-2880
Alberto
Overall Rating: 5 (2 ratings)
Correct Answer
klogata Wed, 12/16/2009 - 08:10
Hope this helps.
Related Content
