CISCO IPCC EXPRESS - SUPERVISOR NEEDS TO DINAMICALLY MOVE AGENTS BETWEEN QUEUES
Answered Question
Dec 15th, 2009
We have a Cisco IPCC Express environment with two queues ("REQUESTS" and "TROUBLES"). In case of, for instance, a great trouble in the customer network (loss of the e-mail service), most of people will call to the Troubles service, so the customer would like to forward some agents to take calls of this queue.
So, we need to dinamically distribute the agents between several queues. Is this possible? Thank you very much.
Correct Answer by Jonathan Schulenberg about 7 years 7 months ago
There is a System Parameter that you can adjust to allow this. Supervisor Access to Teams will allow the supervisor to see the RmCm Configuration within /appadmin. The supervisor can then modify the skill assignments on the agents.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Tue, 12/15/2009 - 05:25
  • Cisco Designated VIP,
    2017 IP Telephony
alicia.vega Tue, 12/15/2009 - 08:02
I have read some documents about "Re-skilling agents". Is this function only supported in Cisco IPCC Enterprise????
Jonathan Schulenberg Tue, 12/15/2009 - 08:05
    2017 IP Telephony
I can't speak to CC Enterprise, only Express. This feature is available in Express if you set the System Parameter accordingly and have the supervisors log into /appadmin.
michael.windon Fri, 09/03/2010 - 11:40
What Service Param are you refering to. I am on UCCX 6.0 and i cant find any param that will allow my supervisors to login to appadmin and only modify rmcm.
Aaron Harrison Fri, 09/03/2010 - 11:56
  • Community Spotlight Award,
    Member's Choice, May 2015
The parameter was in System/System PArameters in AppAdmin; it's called 'Supervisor Access'. You can set it to 'None' 'Sup's Teams Only' etc.
It was (I think) introduced in 5.0, but you may find it's not in v6.0 as that was kind of a parallel universe release for the dying Windows CCM train...
Aaron
Please rate helpful posts...
Related Content
