CONFIGURATION OF TEMPLATES FOR IPCC AGENTS
Answered Question
Dec 15th, 2009
Suppose I have 100 agents in a Cisco IPCC Express environment, and I want to asignate them some skills. Is there any way of configuring a "template", so I can make bulk modifications or I have to make all changes one by one?
Thank you very much!
Correct Answer by Jonathan Schulenberg about 7 years 2 months ago
No. CCX does not have a BAT Template-type concept. Your closest option will be the Assign Skills option within RmCm Configuration. This will let you assign skills to multiple agents all at once.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Tue, 12/15/2009 - 05:24
Related Content
