Is it possible to encrypt data between ISDN connection?
Dec 15th, 2009
Is it possible to secure the data transfer between ISDN connection using encryption algorithms or some other way with cisco routers at both end?
Yamin
Paolo Bevilacqua Tue, 12/15/2009 - 04:01
Are you the end user ?
Your network consultant should be able to explain you the ipsec technology.
Related Content
