Unity 4.2 - Media broken
Answered Question
Dec 15th, 2009
Hi everybody,
I need your help and advice. We aquired a Unity 4.2 to install with CCM6.1 one year ago but we did not unpack the content until current installation for production reasons. We are going to plan the installation and have unpacked all the CDs and DVDs and have found the DVD "Data Store 2000" broken. The CD cover is closed and sealed.
Do you know if can be any trouble in claiming this, even a past year? Is there any way to download the software using the license attached to this CD cover for avoiding time of waiting?
Thank you in advanced and I would really appreciate your collaboration.
Correct Answer by Bradford Magnani about 7 years 3 months ago
The "Datastore 2000" CD is nothing more than SQL.  If you have your own retail copy of SQL 2000, you can use that, it will work just the same.
Otherwise, here is the process you'll need to follow:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a00802262ed.shtml
Hope that helps,
Brad
Overall Rating: 5 (1 ratings)
