cisco 6504. NAT -> Error in Allocating port
Dec 15th, 2009
Hi there.
I`ve made NAT translation
interface Vlan2
ip address 192.168.2.254 255.255.255.0
ip helper-address 192.168.1.1
ip nat inside
interface Vlan3
ip address 192.168.3.254 255.255.255.0
ip nat inside
interface Vlan4
ip address 192.168.4.254 255.255.255.0
ip nat inside
interface Vlan5
ip address 192.168.5.254 255.255.255.0
ip nat inside
interface Vlan6
ip address 192.168.6.254 255.255.255.0
ip nat inside
interface Vlan7
ip address 192.168.7.254 255.255.255.0
ip nat inside
interface Vlan8
ip address 192.168.8.254 255.255.255.0
ip nat inside
interface Vlan9
ip address 192.168.9.254 255.255.255.0
ip nat inside
interface Vlan10
ip address 10.110.115.2 255.255.255.0
ip nat outside
interface Vlan255
ip address 192.168.0.1 255.255.255.0
no ip nat service skinny tcp port 2000
no ip nat service H225
ip nat inside source list 1 interface Vlan10 overload
ip nat inside source static tcp 192.168.9.254 23 10.110.115.2 23 extendable no-alias
ip nat inside source static tcp 192.168.1.1 3389 10.110.115.2 3389 extendable no-alias
ip classless
ip route 0.0.0.0 0.0.0.0 10.110.115.1
no ip http server
access-list 1 permit 192.168.1.35
access-list 1 permit 192.168.1.1
access-list 1 permit 192.168.9.254
ICMP packets r forwarded correctly.
But when i try to access web:
3d20h: NAT: New Inside Entry: couldn't allocate port 1172 for 10.110.115.2 Protocol: 6
3d20h: NAT: translation failed (A), dropping packet s=192.168.1.1 d=93.158.134.8
I thought it is a bug in IOS so I upgraded from   s72033-ipservices_wan-mz.122-18.SXF15.bin to s72033-ipservices_wan-mz.122-18.SXF17.bin
But still the same error.
Can some1 explain what I do wrong?
show run in attachment
Ganesh Hariharan Tue, 12/15/2009 - 08:42
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
The error signifies a symbol (A) which means The "(A)" in the debug output means that translation failed after           routing occurred.
Check out the below mentioned link hope this will help you out to solve your query
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080094e75.shtml
As per your configuration you are doing nat for access list which is having an ip address 192.168.1.1 but from where it is coming and in which interface it getting nat inside.
Ganesh.H
atelkin123 Tue, 12/15/2009 - 23:33
sry, my bad when quoting.
missed Vlan1 in output conf
interface Vlan1
ip address 192.168.1.254 255.255.255.0
ip nat inside
But the problem is stil there.
If i remove
and leave only
Nat works quite fine.
But together overload doesnt work, while 23 and 3389 ports access is fully operational
I thought it is a bug  CSCsj29841
but upgrade from s72033-ipservices_wan-mz.122-18.SXF15.bin to s72033-ipservices_wan-mz.122-18.SXF17.bin  didnt help (
Guys, I am really in panic.
Related Content
