UC520 with Integrated Wireless Controller - Guest WLAN?
Dec 15th, 2009
Hi Netpro Colleagues,
I have a question that I am trying to resolve and I'm not finding any solid information anywhere. I have a customer asking me if there is a possibility to configure a guest WLAN SSID on the UC520 while still providing the normal secure Data and Voice WLAN.
The problem is I can't find any solid information if this is possible or not. Most of the configuration guides that I have found involve using the GUI configuration tool and the screenshots only seem to show the possibility of configuring a voice and a data SSID, however I found a datasheet that seems to indicate that the UC520 can support up to 3 SSIDs.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/product_data_sheet0900aecd8061fb06.html
Is this only possible via CLI? Is this possible at all?
Any help would be greatly appreciated.
Andrew Cook
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
WLAN Specifications
Table 7 lists the WLAN specifications of the Cisco Unified Communications 520 Series
WLAN hardware
• 802.11b/g
• Automatic rate selection for 802.11b/g
• RP-TNC connectors for field-replaceable external antennas (antenna options for extended coverage)
• Antenna diversity
• Indoor range: 1 Mbps at 320 ft (97.54m)
• Wireless Ethernet Compatibility Alliance (WECA) interoperability
• Default antenna gain: 2.2 dBi
WLAN software
• Options to maximize throughput or maximize range
• Software-configurable transmit power
• Wireless Multimedia (WMM) certification
• Service Set Identifier (SSID) globalization
WLAN security
• 802.1X
• 802.11e
• WPA and AES (WPA2)
• EAP authentication: Cisco LEAP, PEAP, and Extensible Authentication Protocol-Flexible Authentication via Secure Tunneling (EAP-FAST)
• Static and dynamic WEP
• Temporal Key Integrity Protocol Simple Security Network (TKIP/SSN) encryption
• MAC authentication and filter
• User database for survivable local authentication using LEAP and EAP-FAST
• Configurable limit to the number of wireless clients
• Configurable RADIUS accounting for wireless clients
• Preshared keys (PSKs)
• Workgroup Bridge Association
SSIDs and Service Set Identification List (SSIDL)
Wireless VLANs
Encrypted wireless VLANs
Multiple Basic SSIDs (MBSSIDs)
Paolo Bevilacqua Tue, 12/15/2009 - 06:30
  • Hall of Fame,
    Founding Member
Yes it is possible.
For sure, use the CLI only.
The GUI is too buggy and unrelaible for professional results.
