Icant access ciscoworks lms GUI?
Dec 15th, 2009
Hi all,
I have a problem with my Ciscoworks LMS.  i have installed ciscowork LMS 3.1 on window server 2003 in a standalone environmentinitially i was able to open its GUI  but now am not able to access its GUI.i can ping it, do remote connection but i cant access its web interface.so am just wondering what could be the problem.anyone with an idea on what am supposed to do.
Joe Clarke Tue, 12/15/2009 - 09:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What error do you get trying to connect with a web browser?    Can you access the UI from the local server?  Post the output of the pdshow command from the server.
jackymasibo Tue, 12/15/2009 - 22:59
Hi Jclarke,
When I try to access the web browser I get the following error; Failed to connect. or the page cannot be displayed as shown in the attached document.Also i did the pdshow command and i have attached its output.your assistance will be highly appreciated.
Joe Clarke Tue, 12/15/2009 - 23:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The pdshow output is truncated.  There is no value in putting text into a PDF file.  Just run this command from the DOS prompt, and post the resulting file:
pdshow > pdshow.txt
Joe Clarke Wed, 12/16/2009 - 00:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It's still truncated.  You must run the command I mentioned in my previous post.  Go to a DOS prompt, and type exactly:
pdshow > pdshow.txt
Then post the pdshow.txt file.
jackymasibo Wed, 12/16/2009 - 00:40
Is it possible to get the output of pdshow > pdshow.txt while accessing the server remotely? because am  only able to connect to the server remotely and am typing those commands you have told me  but am not getting any output.
Joe Clarke Wed, 12/16/2009 - 08:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
As long as you can access a DOS prompt on the server (e.g. over an RDP session) then it will work.  You will not get any output since the output is redirected to the pdshow.txt file.  Just run the command, and post the file.
