How to lock the ip phone cisco
angeolivier
Hello all,
Want to know how i cant lock or make authentication to the IP phone (7931,7911,7941) and how activate a ssl
thanks
6 Replies 6
The Cisco 7900 Series does not support an embedded SSL client.
Marcos
Ok no ssl but is not possible to lock a phone ?
Lock it web access you mean? If so, this is there by default (authentication challenge).
Marcos
Same question.
I would like to lock some 7961s and 7911s with a password, so that when the user leaves the desk, no one else can use the phone.
Tks.....
If you don't use Extension Mobility, you do not have a choice.
You could use Office Manager to temporarily restrict call permissions and disable voicemail for that user:
http://www.cisco.com/go/officemanager
Marcos
CISCOELITE
Oooops,, hehe
OK,,,
Gracias,,,
