Multi Service port report
Dec 15th, 2009
I'm trying to run multi service port report for Cisco 7606 runing 122-33.SRCR1 image and I get the following error:
INVREP0060: None of the selected device(s) are multi-service port capable. Select multi-service port supported devices to generate the report.
I belive 7600 are pretty much like Cisco 6500s but why 6500 is supported and Cisco 7600s are not? I wan tto run power supply report, is there anyway that I can run power supply report?
idea?
Joe Clarke Tue, 12/15/2009 - 10:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
RME currently has a hard-coded list of chassis types which are multi-service capable.  There are 7600 types there:
cisco7606
c7609
cevChassisCisco7606
c7603
cevChassisCisco7609
What chassis type is your router?
nawas Tue, 12/15/2009 - 11:04
Here is the snmpwalk output
SysObjectId
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::cisco7606s
I have the following sup module
Route Switch Processor 720 (Active)    RSP720-3C-GE
Joe Clarke Tue, 12/15/2009 - 11:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This isn't the chassis type, but probably shows the issue.  The chassis type can be obtained by walking the entPhysicalTable from the ENTITY-MIB.  The entPhysicalVendorType for the chassis element will indicate the actual chassis type.  My guess is that it's an 'S' specific chassis.
nawas Tue, 12/15/2009 - 11:21
Yes it is not S type chassis. So do you know WHEN it will be supported? It's strange that S type is the newer chassis and it is supported but the non-S type is not.
ENTITY-MIB::entPhysicalDescr.1 = STRING: Cisco Systems Cisco 7600 6-slot Chassis System
ENTITY-MIB::entPhysicalDescr.2 = STRING: Cisco Systems Cisco 7600 6-slot Physical Slot
ENTITY-MIB::entPhysicalDescr.3 = STRING: Cisco Systems Cisco 7600 6-slot Physical Slot
ENTITY-MIB::entPhysicalDescr.4 = STRING: Cisco Systems Cisco 7600 6-slot Physical Slot
Joe Clarke Tue, 12/15/2009 - 11:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This still doesn't show what I need to see.  You need to show the value of entPhysicalVendorType for the chassis entity.
nawas Mon, 12/21/2009 - 11:24
I have attached the output of snmp walk, for some reason i couldn't run entPhysicalTable from the ENTITY-MIB, can I run it from the device center?
Joe Clarke Mon, 12/21/2009 - 11:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you can walk the table from Device Center.  You may need to use the OID .1.3.6.1.2.1.47.1.1.1.
Joe Clarke Mon, 12/21/2009 - 18:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
As I suspected, the chassis type is unknown to RME.  You have a cevChassisCisco7606S which is not listed in the RME code.  The code would need to be enhanced to include the 7600 S chassis.  I recommend you open a TAC service request so that this issue can be documented.
