LMS 3.2 user tracking
Answered Question
Dec 15th, 2009
currently we are not managing any Cisco AP's on LMS and we did put them on exclude list. how ever now these Ap's detected as end devices. and that created confusion on our daily inventory check up script. we don't want Ap's to count as end devices. another problem we have with Ap's. we are using host file for Network device resolutions. end devices using DNS for name resolution. because of that now all the Ap's discovered by ip address since they are not registered on DNS. we have close to 3000 autonomous Ap's that create a biggest challenge on our user tracking.
my question is there any way to setup LMS not count AP's as end devices. or any kind of suggestion to avoid this scenario. thanks in advance.
Correct Answer by Joe Clarke about 7 years 4 months ago
I assume that the APs are not configured for trunking.  If they were, then they would not show up as end hosts unless you configured UT to process end hosts on trunk ports.
If they are not configured for trunking, then the only thing you could do would be to setup subnet filters to exclude switches to which APs connect.  This would, however, mean that no end hosts would show up for those switches.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 12/15/2009 - 10:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
eliaspaulos Tue, 12/15/2009 - 11:34
Thanks a lot, yes it's not configured for trunking. unfortunaitly subnet filter is not working for me because afecting everything else.
